Помогите пожалуйста с выбором колес
Тема в разделе "Колёса и шины", создана пользователем G1n, 29 мар 2016.
Статус темы:
Закрыта.
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Всем здравствуйте! Я тут новичок, поэтому пожалуйста не пинайте сильно, если что сморожу)
    Собственно задумал я поменять колеса и ничего не понял) Помогите пожалуйста с этим вопросом.
    Менять хочу оба колеса с втулками, на данный момент выбор пал на втулки Nukeproof Generator 2013 года в качестве задней и 2016 в качестве передней, на ободах Mavic XM319, по характеристикам:
    Nukeproof Generator Rear MTB Hub - QR
    Nukeproof Generator 135mm/QR rear hubs are essential components for any high-grade wheelset, providing smooth and long-lasting bearing performance and a light weight that belies their ability to take hard knocks.
    Designed for bikes with 135mm rear dropout spacing and QR (quick-release) rear axle.
    A tough but lightweight 7075-series aluminium main hub body features cold-forged construction for optimum strength and fatigue resistance while extensive CNC machining shaves excess weight without compromising structural integrity.
    The hub features a total of five sealed cartridge bearings: two on the drive side to help spread the loads of pedalling forces through the hub, one on the non-drive side and a further two in the freehub body.
    A low friction seal between the bearings and freehub body eliminates contamination of the bearings from ingress of water and dust.
    Six pawls with leaf springs are located in the main hub body for ease of maintenance and engage into a 30-tooth steel ratchet in the alloy freehub body for additional strength and increased leverage ratio, which provides positive engagement and super fast pick up for increased acceleration.
    The alloy cassette carrier has been cold forged with extensive CNC machining to exacting tolerances and features a hard anodized finish for durability and strength.
    Featuring new graphics for 2013 and available in black, silver or Nukeproof yellow.
    Features:
    • 7075 alloy main hub body
    • 7075 alloy sub axle
    • 4 x Sealed 6902 & 1 x sealed 15268 bearings
    • Alloy freehub body with 30T steel ratchet
    • 6 pawls with leaf springs
    • 32-hole
    • International Standard 6-bolt disc brake interface
    • New graphics for 2013
    • Designed to fit frames with 135mm hub spacing and wheels with QR axle.
    Specifications:
    • Width: 135mm
    • 67mm flange diameter
    • Spoke PCD 58mm, spoke hole diameter 2.3mm
    • Left side Axle edge-to-flange diameter: 33mm
    • Right side Axle edge-to-flange diameter: 45.5mm
    • 15.25mm end of axle to disc mount face
    • Weight: 305g
    Втулка передняя Nukeproof Generator - 15mm/QR
    Втулки Nukeproof Generator являются ключевым компонентом любого качественного комплекта колес, обеспечивают хорошую работу и долговечность, отлично держат удар несмотря а легкий вес.
    Крепкий и легкий корпус втулки изготовлен методом холодной ковки из алюминия 7075 для обеспечения прочности и усталостной стойкости, а обработка на станке с ЦПУ типа CNC позволила убрать лишний вес без ущерба для структурной целостности.
    В состав втулки входят пять герметичных картриджных подшипников: два на ведущей стороне для распределения усилия от педали, один на обратной стороне и еще два внутри корпуса втулки.
    Соединение подшипников с корпусом втулки защищает подшипники от попадания воды и пыли.
    15 мм/QR-легкая втулка для трейла / XC набора колес, чтобы соответствовать 15 мм Thru-axle / QR.
    Характеристики:
    • 15 мм или QR
    • Два герметичных подшипника 15268
    • Вес: 149 г
    Вопрос собственно вот в чем, у меня кассета новая shimano на 8 скоростей (в дальнейшем планирую замену всей трансмиссии), подойдет ли она к этой втулке, и как на взгляд велогуру получаться колеса? Или возможно лучше присмотреть что то еще? По катанию так: 10% город, 85% лес, грунтовка, проселочные дороги ну и 5% бывает бездорожье (поля и т.д.), накатываю в районе 1000 км. за сезон (+/- 200 км.)
    Так же как альтернативу предлагают втулки Xenium, кто что скажет?
  3. Flystyle
    G1n, на колёса в сборе не обращали внимание?
  4. sho-di
    Например литьё? Модно и не развалятся...
    Flystyle нравится это.
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Flystyle, Да как то не чего путного не нашел в районе этой суммы, а есть что посоветовать?
    На данный момент остановился на такой комбинации:
    1. Втулки те что в шапке (Nukeproof Generator)
    2. Обода аналогично из шапки (Mavic XM319)
    3. Спицы DT CHAMPION
    За все про все вместе со сборкой на чайне выходит около 17500 за комплект (с ободной лентой Nukeproof)
    Смотрел в сборе, ну только если какие нибудь shimano можно подобрать по этой сумме, но что то мне очень сильно подсказывает что Nukeproof втулки будут половчей и самое главное куда больше проходят
    По бюджету как бы уже 17500 дороговато честно говоря, но как бы еще готов отдать такие деньги, больше - не смогу.
    Колеса хотелось бы взять такие, что бы поставил и забыл (своевременное ТО не исключается), и хватило их на долгое время...
    Кто что скажет?
    sho-di, Это сарказм? Или так оно и есть? Просто что то вот литье я совсем исключил, как то мне не очень)))
  6. sho-di
    G1n, а сам как думаешь?
    Не забудь, что колёса ещё собрать нужно, а это тоже деньги.
    Лучше ищи уже готовые, в 17500 можно уложиться.
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    sho-di, Так а какая разница? 17500 это уже вместе со сборкой, то бишь будут уже готовые собранные колеса.... Собирают по отзывам очень хорошо и качественно, по времени пара дней...
    Или же есть какие то рекомендации конкретно по фирме? В какую сторону капать то?
  8. sho-di
    G1n, извини, не заметил, что со сборкой.
    Тогда бери, получатся нормальные колеса, не самые лайтовые, но прослужат долго, если конечно не долбится во все поребрики и ямы.
    Ты что-то писал про кассету на 8 скоростей, у тебя точно кассета?
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Да, конечно кассета, сам менял наверное месяц назад... Shimano'вская если точнее, если еще точнее Shimano CS-HG41
    Пока так, в дальнейшем хочу поменять, но так как это потянет за собой смену переключателя, монетки и так далее, пока так хочу оставить.
    Подойдет втулка? Или они все одинаковые?
  10. Flystyle
    G1n, ничего не имею против мавика,но в прошлом году за 17500 можно было довольно годные шимановские колёса в сборе взять.
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Flystyle, А в чем будет принципиальная разница? Там где смотрел shimano были только 15 (по модели) где-то около 11 тысяч, могу конечно еще где то поискать если они действительно выйграют в качестве...
    А вот по кассете так что то никто и не сказал
  12. sho-di
    Все шимы на насыпи, а нюки хотя бы на промах, т.ч. шимано не авторитеты в колесах... Ещё конуса и прочие оси- шарики в их втулках.
    Поверь мне шимано может в трансмиссии и тормозах могут составить конкуренцию, но в колесах они далеко отстали.
    G1n и UPельсин нравится это.
  13. Flystyle
    G1n, самособранные качеством конечно выше будут,но и вес чуток выше за счёт более надёжных втулок. У шиманских в основном насыпь. Опять же,смотря что катать. Я вот хочу себе собранные шыманы,мне так проще,купил,воткнул,поехал.
    G1n нравится это.
  14. sho-di
    НЕ В ОСНОВНОМ, А ВЕЗДЕ, КАРЛ, ВЕЗДЕ, НАЧИНАЯ ОТ АЛИВИО, ЗАКАНЧИВАЯ САИНТОМ И ХТ!!!
    G1n нравится это.
  15. Flystyle
    sho-di, я то не спорю и те же кроссрайд или кроссмакс лучше чем большинство шиман,но многое и от того зависит как это эксплуатировать.
    П.с. сам лично саинт не ковырял,поэтому сказать не могу.
  16. sho-di
    Flystyle, я тоже много чего не ковырял, но есть такие вещи как мануалы, глаза, мозги, ещё придумали алфавит и чтение, если всё вместе сложить- отлично получается...
    Информации туева хуча, научитесь ей пользоваться, а не создавать 100500-ю тему, о том что уже разжёвано 100500 раз.
    P.S. Flystyle, это не лично к тебе послание.
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Ну значит все же Nukeproof, хорошо, с этим определился, (спасибо большущее всем отозвавшимся!) остался маленький вопрос) Что с кассетой то? Все норм будет? Просто вот с эти как раз загвоздка, я лично думал что втулки тоже делятся по скоростям и могут быть как на одну скорость, так и на группу (8/9 и т.д.), однако на днях мне сказали (в магазине велозапчастей) что они все идут на 8/9/10, и вот что то я прям и не знаю, может кто что скажет?
  18. sho-di
    G1n, да всё нормально будет с твоей кассетой. Только обрати внимание на материал барабана у втулки.
    Rottweiler и G1n нравится это.
  19. TopicStarter Overlay
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Так, а что конкретно смотреть? Втулка алюминий, 7075, барабан такой же алюминий, есть какие то загвоздки? То есть получается что? Можно брать, но лучше не экстрималить?
  20. sho-di
    Барабан алю- бери кассету на алю пауке, сталюга будет оставлять закусы на барабане.
    G1n нравится это.
  21. TopicStarter Overlay
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Да блин)) это получается еще наверное тысячи 4, соответственно если дешевле то только стальной барабан искать?
    ЗЫ Так получается и в 4 не уложишься, там же тоже не все звезды на пауке.... А стальной барабан что то не могу найти, все что на промах - то люминий...
    ЗЗЫ Начитался всего подряд, нашел фото данной втулке после кассет без паука, это после 4250 км. на кассетах без паука
    Интересует мнение знатоков, если поставлю новую кассету без паука на один сезон (примерно 1000-1500 км), затем поменяю на кассету с пауком, нормально все будет? Не сильно критично? А то не хотелось бы отдать деньги за колеса, что бы в дальнейшем опять менять втулку
  22. Flystyle
    G1n, смотря что вы катаете.
  23. TopicStarter Overlay
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Пожалуй больше КК, но как бы в случаи с этой втулкой понимаю что лучше брать плавные старты и небольшую нагрузку в горку (пока не поменяю кассету), что скажите?
  24. Rottweiler
    G1n, тебя sho-di, постом выше предупредил о пауках. В смысле о материале. Как раз о том он и говорил, что ты выложил ;)
    Cталь/алю - получишь забоины, как бы мягко не стартовал.
    Ну попробуй, если что надфильком пройдешься да и всего делов...
    Flystyle и G1n нравится это.
  25. TopicStarter Overlay
    G1n
    G1n Начинающий
    29 мар 2016
    Суворов
    Cannondale Trail 6
    Спасибо! Я про забои то понял все, я просто хотел уточнить на сколько это критично) просто барабан в случаи чего что то не на много дешевле втулки получается) Всем большущее спасибо!
  26. Flystyle
    G1n, всё в твоих руках,хочешь убьёшь и на пауке...:D
Статус темы:
Закрыта.
